And when your filesystem driver gets corrupted? Or your sata driver? Or that shareware thing you downloaded last month makes a mistake and deletes a file? Pressing the Delete key isn't the only way to delete a file. And deleting a file isn't the only way to make it unusable - if someone takes your term paper and replaces all the instances of 'e' with 'q', or runs MS Grammar check on your C source, the files are rendered useless. And double-useless, since the changes are immediately replicated to the other disk!este said:If I delete something from my RAID-1 there better be a good reason for doing so. Its all marked read-only so there is a prompt, THEN there is a recycle bin, and THEN if for instance I wake up completely retarded and still manage to delete my important files, there is undelete, after that I wouldn't even really care b/c they aren't THAT important.
Wrong! You have the same copy on two disks. The copies are kept in sync automatically, so if something modifies one drive both copies are broken. The only way having 2 copies is a backup is if they do not automatically overwrite each other.este said:Like it or not I have 2 physical copies of all my important files.
If 95% of people jumped off a bridge...este said:FOR ME - 2 physical copies IS a backup. Thats WAY more then the 95% of people out there that are using 1 hdd drive.
If it's not an issue, why are you doing backups? It's never failed so it can't.este said:I have no use for offline, read-only, or permanently stored backups ... I still make a very infrequent true backup and throw it in the bank. In case of fire or some bs. But, considering how many times my system has been stolen and burned (zero times). Its not an issue.
So why are you presumptuous to tell others your system *is* good enough for them?este said:I certainly would not be some presumptuous to tell someone their system is not good enough for them.
longblock454 said:Amen, this concept often takes IT professionals years and multiple failures to finally comprehend.
The only true backup is offsite and asynchronous.
