RAID problems with DFI UT SLi-DR
phungilax
On the boot up screen I go through the raid configuration by pressing F4. I set it up to raid 5 and then when I enter the windows setup I install the SIL3114 Windows 64 bit RAID drivers. However I still get the error message that "Setup did not find any hard drives installed in your computer....Press F3 to continue." Any possible reasons this is happening? The bootup shows the drives in a raid configuration fine. Its just that windows doesn't see it. Possible bios/driver issue? Thanks
i know i shouldn't have to ask, but, you're running the 64bit version of xp?
