I have a Silicon Image 3114 RAID controller (Integrated on my ABIT IC7-MAX3 motherboard). I've been running 2 Seagate 7200.9 300G drives on that controller in RAID-1 (Mirrored) for quite a while with no problems. The drives have SATA2 (300) interfaces.
I recently swapped out the 300G drives for a pair of 750G Seagates with more or less the same specs, they are 7200.10 models, same SATA2 interface.
Now when I try to boot into the RAID firmware to start mirroring, the system hangs when detecting the drives. Anybody know if there is a capacity limit with the 3114? I can't find any mention of this in the docs that I can find. As this is an intergrated chip, I can't update the firmware (Currently it's 5.0.31) unless ABIT releases a new system BIOS, which does not look promising as the last one was in November of 2004!
I'm going to try putting the drives into SATA1 (150) mode with a jumper, just wondered if anyone here had an answer!
TIA!
thePP
TIA!
thePP
