RAID Boot drive Only for O.S.?
I don't know what the difference is with using my WD RAPTOR as a boot drive for the OS and apps,then using my 500GB for storage.....OR someone telling me to RAID the 74GB, then put ONLY my Operating system on it. Isn't that the same thing?
Is there any way, (or do I even want to) Install the O.S. on the 74GB Raptor, then install programs to the storage Drive? Or do they all belong on the same drive? I'm trying to use more resources on my Photoshop and Studio Pinnacle Video Editing.
I presently have three internal hard drives.
Western Digital 74GB RAPTOR,
Western Digital 500GB HDD, and a newly bought
Western Digital 2 TB Caviar Green HDD, which will also be used for saving huge video files.
When I installed XP Home 32 Bit, a few years ago, I used the WD Raptor for boot drive for the O.S. and installed programs, and the 500GB for storage.
In using Pinnacle Studio 15HD, it installs different files all over the boot drive and the 500GB storage drive, and its very hard to know where all these needed files are, also need to increase resources when I use both Photoshop and Studio.
Someone mentioned to use ONLY the WD 74GB RAPTOR to boot my operating system by USING RAID, and use both the other two drives for applications, and storage .is this an accepted way to configure a system so the O.S. and programs works faster, and more efficient? Thank you!
I have not used the RAID option before, and wondered if its hard to do? I cant wait to dump XP and get the Pro Win7,so Im upgrading MoBo hardware first.
Now I'm thinking of just using my 74 GB Raptor for an extra Storage HDD, then using the 500GB for my boot drive.BUT the consensus is the raptor is faster for apps and OS.
Thanks again?
Thanks again?
