I have a 3tb Raid 0 just two 1.5 tb drives. I use it as a HTPC/ File server for my house. Currently it is in a box I have rocking a 3.4ghz P4 with windows 7. The video encoding is not quite fast enough with this for it to handle 1080 mkvs so I was thinking about moving the raid to another box with a dual core amd of some kind. The mother board on the P4 box was lacking in sata ports so I have the drives raided through a PCIe raid card but if i remember correctly the cards drivers did not support NTFS so it was either use FAT and loose a lot of my space or software raid the drives. I software raided of course.
If I move this raid to a new box will the raid rebuild its self automatically? If not what would I need to do to have it rebuild its self? Do I need to know the block size I used etc...?
Also... The boot drive is a different drive these just have movies etc on them.
Thanks
Thanks
