Raid messing up my dvd burner
Hey guy, i recently just built a new computer, i7 940, intel dx58so, 6gb ram, 2 wd640 blacks in raid, and samsung dvd burner.
However, after installing windows, my sata dvd burner stopped working. I can burn blank disks, but it would fail while verifying. Whenever i put a cd/dvd into the drive and try to play the music or open the files, the program would hang and i have to force quit.
I googled about the problem and it seems like it has something to do with my hdd raid. Prior to the new build, my q6600 build had similar problem(also with the same raid), except it would read everything but can not recognize blank media...
Is there any solution to this problem? Any help would be appreciated... Thanks!
You should tell us more about your system:
What are you running for a power supply?
Do you overclock anything?
How do you have your raid set up?
i have a seasonic 850w power supply, raid 0 with sata port 0 and 1.
the dvd burners on port 3
the i7 940 is overlocked to 3.5ghz.. although i duno why it would matter...
