NrthnStar5
- Jan 6, 2005
Hi everyone. I have a raid level 0 stripe size at 4kb right now, however i'm trying to find the BEST stripe size for optimal gaming performance. Can anyone help ? Thanks!
kick@ss said:RAID 0 is completely useless for gaming.
And here's some benchmarks:
http://www.anandtech.com/storage/showdoc.aspx?i=2101&p=10
UltimaParadox said:Sadly this is true, save your disk space and don't RAID
No. Don't RAID.I hate resurrecting an old thread, but I'm playing EQ2 and Vanguard currently and have them set to maximum textures. I've been told the file sizes needed to load into the vid cards are huge and thus bottle neck on my single raptor. I have ordered a 2nd raptor and am curious, the file sizes are huge, and my SLI'd 8800GTX's do pretty well, but with 2gb of ram and the cpu at 3.5ghz i'm still getting hitching... So I wanted to try out another 2gb of ram and eliminate the virtual memory, and 2nd try raid zero 150 raptors...
So what is the general thoughts on this. I mean with very large files and the fact that textures in these 2 games are constantly being loaded into the GPU memory, will I see what i hope is a 20% boost in performance with the above 2 upgrades?
That is incorrect. RAID-0 is also very good at serving large read requests.RAID 0 is only beneficial when writing large files to disk, like video.
is there any extra cpu overhead to take into consideration when running a raid setup?
Ok, lets clear up a few things:
Also my improvement estimate is combining a move from 2 gig to 4gig
Sunin said:and adding in the twin raptor 150's in raid 0. So I guess I'm still hoping for 20% boost.
Sunin said:A bit of a question, will the system auto recognize the raid when I plug the 2nd drive into the raid port on my 680i? Or will I need to setup something? Any good guides on setting up a raid 0 out there?
Thanks in advance from a raid newbie!
I like my raid 0 array. I am always one of the first to load in a game. Helps in BF2. Lot cheaper then raptors and has similar performance imo. I have a external drive and a burner for backing up. So if my array goes down I have a reason to re format and minimal data loss. Now it could be because I have a already fast rig, but a friend of mine with a similar system except no raid loads like a few seconds slower in cs:s. Non gaming wise, files access is pretty quick, moving files is fast, and I have no slow downs when saving large files.
There is a difference, but its up to you if you care about a few seconds. For bf2 is matters because it means 1st pick at vehicles
Please DO NOT RAID 0 for gaming purposes, this has been beaten to the death! You want HD performance for gaming - get the king raptor150 or the revised raptor74gig edition!
wouldn't raiding two Raptor 150's give you even greater performance?
One for paging file (go for low seek time here)
with enough memory wouldn't it make sense to remove the page file? I mean 2 to 4 gig do you really need it?
