RAID Issues.
Hello. I have an issue with my onboard IDE RAID controller, it keeps my machine from booting. When I have it enabled as a raid controller, XP's loading bar scrolls continuesly, with no disk usage. The odd part is that the machine will boot with the controller set to IDE (with different disks.) Both of the disks show up in the BIOS of the device, in Array 0.
Someone said wiping the BIOS may help, I did that, but it didnt change anything.
Thanks for any and all help. :)
Double check your hard drive jumper settings. RAID controllers are often quite sensitive to them, more so than a normal IDE controller.
