Raid help
Frogbutt
Im setting up a new server and just installed a (RocketRaid 454 4channel ATA Raid 5 host adapter) with 8 200gig IDE drives. I installed the raid card and plugged my 8 drives into it (master/slave jumpers set correctly) the computer recognises the card fine and I installed the drivers for the card with out problem. It came with some windows mangement software that I used to create the array. I built the array with Raid 5 it seemed like it built fine, no errors reported, here is the end results,
Anyway seems like its all setup but windows doesnt report my new uber amount of hd space. You goto explorer and it just list my C: (OS drive) and my D: (cd driver) none of the drives connected to the raid card show up. Anyone with raid experience no what im not doing?
Start > Run > (type) diskmgmt.msc > RClick unallocated space, partition and format ? :p
