EnforcerGT
Bad Trader
- Feb 9, 2002
Ok, so i decided to try and raid-0 my 40gb Maxtors. I got into my raid controller right after bios, and created my raid0. I got into windowsxp installation, and from there I put in the raid driver. Windows detected one 80gb hard drive for the installation to go in, so i installed it, and everything was good.
So it reboot and right where it should load windows, it goes back in to windows installation. So i go to the select partition and it says windows already exists.
I dont understand.... the raid is all good except it goes back into windows installation everytime. The HDs are not corrupt because I was using them before I decided to raid them.
I connected a HD1 to my UIDE1 slot, and another HD2 to my UIDE2 slot. The UIDEs are IDE slots for my raid.
Im using an EPOX 4BDA2+ mobo with HighPoint 372 raid.
Any help/advice is appreciated. Thx in advance
