Raid drivers on USB
phungilax
I was wondering if there is a way to load the RAID and SATA drivers onto a USB as I don't not have a floppy. When I press F6 to set up the RAID it asks for the floppy. Can I have it so that reads the USB?
I've never seen the USB method, but you can slipstream SATA/RAID drivers into a winXP install cd using nLite.
http://www.nliteos.com
I do feel you're pain on the floppy, I have my original drive from my first comp I bought in 1998. I'd like to shoot it with the 12 gauge.
use nlite to slipstream the raid drivers: http://www.nliteos.com/
copy txtsetup.oem into the same directory as the raid drivers (.inf, .sys, etc) and add the driver. Be sure to select the text option.
