Looking to upgrade a home-use file server's RAID card. It's a desktop Intel board (i865 chipset) with a P4 3.0GHz and an Intel GbE NIC. The current RAID card is a Promise Tech 4 port IDE card (S2000 model, I believe) with 4x300GB parallel ATA drives. Drives are in a RAID-5 array, and are mapped just as storage (operating system is on a separate dedicated drive).
I'm looking to get a new SATA controller card with at least RAID-5 capability. Four SATA drives would be attached, with each drive anywhere in the 1-2 TB capacity (all four would be identical, I just need to check prices first). Operating system would likely be some version of Windows -- either XP Pro or something newer. Linux support would be a plus, but is not a requirement.
The motherboard only has the normal 32-bit PCI sockets available, so any suggestions would have to use that socket type. (Side thought: PCI-X would work, right? But just run not at the card's top speed. Which wouldn't really matter, as this is still home use with at most three people connecting.)
