RAID card review/suggestion
toolskizm
I've been debating getting a RAID array started. I think I'm finally financially able to do so. The hardware RAID looks more appealing to me as I want to be able to transfer it if needed, and expand. I'm running Windows also, so I'm not really quite sure on how great software RAID setups are and the pros/cons versus a hardware setup. I'm looking at the HighPoint RocketRAID 2320. It's 8 port and expandable to 16. Do any of you have any suggestions or reviews on the card? There's a bit of mixed reviews about it on Newegg. I would like to keep the budget around that price as it's already expensive enough. I'm looking to do 5 750GB currently. The problem is I barely have any space available to make the RAID, so I'll be having to get three drives free of space to get it started. Then, I'm hoping transfer over to the 3 drive RAID and free another drive then expand to 5. Seems right doesn't it? I'm no expert on RAID, but from what I've read this is possible with the online expansion.
EDIT: This is going to be a RAID 5 by the way...or so is the plan as long as I'm thinking of doing this right. If not, please let me know...I don't want to purchase this stuff and be stuck somehow.
So I'm curious about the RocketRAID 2320 and maybe any other suggestions around the same price and same features if you don't suggest this card. 8 ports and SATA is a must as I already have 5 drives...and of course do nothing, but SATA. Thanks in advance.
