RAID Card Recommendations/Reviews
Buzzar
Hi,
I didn't see a card review thread out there unless I missed it. Is anyone out there familiar with the Addonics Technologies ADSA4R5?
I found it on the web but would like to know if anyone has any good/bad experiences with it. I just upgraded my MCE box for HD and am now thinking of using the old system to build a NAS. Any reviews on RAID cards, MB/Card/OS/etc. combinations that work or don't work would be greatly appreicated.
From the web site:
Specifications
PCI
Compliant with PCI Specification, revision 2.3
Supports 66 MHz PCI with 32-bit data
Internal application interface multiplexed to 4 ports
All registers appear in unified memory space
Full-chip command completion status accessible with single PCI burst access
I/O port access to register space
Low Profile PCI form factor​
High Speed Serial ATA
Fully compliant with Serial ATA 1.0a and Serial ATA II Extensions to Serial ATA 1.0a Specifications revision 1.1
Support SATA II transfer rate of 3G/sec (300 MB/ sec)*
Compliant with SATA 1.0 specification
Supports SATA II First-party DMA commands for Native Command Queuing (NCQ)
Supports Serial ATA II Port Multiplier 1.0 Specifications revision 1.1
Plesiochronous, Single PLL architecture, 1 PLL for 4 ports
48-bit LBA support
Four independent DMA channels with 256B FIFO per channel
Virtual DMA in PCI with serial link in legacy PIO mode
Supports command buffering for ATA TF shadow registers
Independent Link, Transport, data FIFO, command fetch, scatter/gather, and command execution
31 Commands and Scatter/Gather Tables per Port
Supports ATAPI devices: CD-ROM, DVD-ROM, etc.
Supports bootable drive
Hot-Plug capable
Supports SATA active signal for 4 separate LEDs
Built-in firmware RAID support for RAID 0, 1, 10 or 1+S, RAID 5, JBOD
Supports Spread Spectrum in receiver
Independent 256-byte FIFOs (32 bit * 64 deep) per Serial ATA channel for host reads and writes
Compliant with PCI Specification, revision 2.2
Integrated PCI DMA engines
Four Pin header on board for LED connection
32 bit, 33/66MHz fully compliant PCI host interface
drivers for Windows 2000, XP and 2003 Server​
* The onboard SATA controller chip is SATA II compliant and capable of 3G/sec. Depending on the clock rate of the PCI BUS, the actual data transfer may not be able to reach the 3G/sec data transfer.
Found a few reviews by Xbit Labs that may be of use to some of you. The cards they reviewed are a bit too pricey for me but do seem to have some good features. Here are the links:
3ware 9500S-8 SATA RAID Controller Review
Category: Storage
by Alexander Yuriev
[ 08/06/2006 | 09:25 AM ]
We resume testing multi-channel SATA-RAID controller cards. Today we are going to introduce to you a not very new, but certainly revolutionary solution from 3ware – 3ware 9500S-8 controller. Find out what is so revolutionary about it from our detailed review!
http://www.xbitlabs.com/articles/storage/display/3ware-9500s8.html
LSI MegaRAID SATA 300-8X Controller Review
Category: Storage
by Alexander Yuriev , Nikita Nikolaichev
[ 12/23/2005 | 07:22 AM ]
We would like to introduce to you an 8-channel Serial ATA II RAID controller from LSI supporting also High-Speed PCI-X bus, featuring a large cache buffer and a battery to power the cache chips in case of emergency server shutdown. All these features make the new controller a top-end product, of course. Read more in our detailed review!
http://www.xbitlabs.com/articles/storage/display/lsi-megaraid300-8x.html
Promise FastTrak TX4300 Serial ATA RAID Controller Review
Category: Storage
[ 10/20/2005 | 04:09 PM ]
It’s been a while since we offered you controller card reviews, but today we are going to correct this mistake. WE would like to introduce to you a new four-channel Serial ATA RAID controller from Promise FastTrak series – TX4300. Are you building a fast and reliable storage subsystem? Check out the review, it might be something you need.
http://www.xbitlabs.com/articles/storage/display/promise-ft-tx4300.html​
One more review that may be of interest. This one is of the SiI3124 controller from Silicon Image used on the Addonics Technologies ADSA4R5.
SiI3124 SATALink 4-Port PCI-X Host Controller from Silicon Image
Category: Storage
[ 03/23/2005 | 10:01 PM ]
We would like to introduce to you a new 4-port Serial ATA II RAID controller from Silicon Image, which came to replace the predecessor, SiI3114. The newcomer supports 133MHz PCI-X bus and provides excellent results scalability, extremely high linear reading and writing speeds, and stable performance growth for RAID 0 arrays configurations. Read more in our new review today!
http://www.xbitlabs.com/articles/storage/display/sil-3124.html​
