RAID card question
JeffBlair
Hi all. OK, right now I'm running a RAID5 IDE setup. I'm about to make the plunge into SATA. I was looking for a card that can do more then 2T for a volume.
Most that I've seen will only support up to 2T. I was looking into getting 3 or 4 1.5T drives. and would like to just put them all together.
I'm going to be putting it into a Linux system, so the card will need to be able to be used by that.
And, having a program that is able to run in Linux, or a web based one would be a BIG plus. :)
Here are some of the things I would like for it:
=Linux support
=Linux program support
=Hot add/expantion
Any ideas?
