RAID array consistency checks
HDClown
My Adaptec 5405 RAID controller supports background consistency checks. Is this something I should enable? The Adaptec Storage Manager says that if your card doesn't support background consitency checks, then you should run a manual check each week, so that leads me to believe I should enable it
Also, ASM has a verify and verify with fix option. Does anyone know if the background consistency checks do a verify with fix, or just a verify?
It's a good idea to do so. I data scrubbed my software arrays once a week before I had hardware cards and now I have scheduled verify jobs on my 3ware cards.
I'd run the verify with fix. Just schedule it to run sometime when you're not at the computer (at work, sleeping, etc). :)
checking raid1/5/6 for consistency once a week or so is good idea. I run a check on my raid5 every monday while im at work :p
My RAID5 arrays automatically get checked with repair every Monday at 0400Z.
Adaptec Storage Manager lets you schedule a Verify+Fix (Build/Verify), and you also have the option to enable consitency check with a scheduled interval on the controller itself (shortest interval being 10 days).
I'm not quite sure if there's a difference in the two. The help isn't very useful with technical details between the two.
Awesome, I didn't even know the storage manager had this option... Just scheduled my first verify/fix. :)
