Raid and raptor problem
essi1553
Ok so I have 2 200gb maxtor drives in raid, and it works perfectly.
Today I got a raptor 74gb drive (single) booted up the system and installed windows, and now I cannot find my 200x2 raided drives. However while in bios testing settings i was able to startup my pc on either set of windows installations, either the raid setup or the single raptor setup.
What must my settings be to enable both to work continusly? Do I need to buy another raptor drive and run them in raid to view my complete hard disk config and still use raid?
I am using a dfi expert (sli-dr) board.
Last but not least heres what i want from this system. I want to retain my info on my maxtor raid setup, as well as have the raptor as the boot drive. My plan was for my pc to recoginse my raid setup and use partition magic to combine the raid drive back into one partition instead of the 2 sections it is now.
Please help,
Thanks,
Essi
You'll need to install the RAID drivers for your controller. They're probably on a floppy in your motherboard box, or they'll be on the manufacturer's website.
