I just got a new system, specs are
Maximus Formula motherboard
QX9650
8 gb G.Skill DDR 2 PC8000
WD Raptor X 150gb
WD 250 gb SATA 3 drive
WD 500 gb SATA 3 drive
Windows XP x64
so, in my bios I can set the SATA controller to either emulate the drives as IDE, I can set it to AHCI or RAID. I was reading if I set RAID, but keep the drives as standalone I get the benefits of AHCI as well.
now I tried to install windows with the F6 drives, but i've run into some problems with it set to RAID. windows will install, but when it goes to load i get a quick blue screen and it resets which leads me to believe its a driver issue.
I'm gonna keep working it, but I guess the main question here is should I even bother setting RAID in the bios, or should the IDE emulation work fine? is there that much of a performance gain with AHCI or am I just spinning my wheels for nothing?
QX9650
WD Raptor X 150gb
Windows XP x64
