zootielolo
- Jun 19, 2010
So i have lurked here for a while and finally had a question I couldn't find with a search. I recently switched from a LSI 9650se controller to a LSI 9750 and a HP sas expander. My previous array was (4) 1 tb drives in raid 5. I was running low on space, so I decided to increase my capacity and bought (4) 2tb Hitachi drives. I also changed to raid 6. I contacted LSI to ask if different size drives could be fully utilized if they were larger than the current drive size. I was told that when I migrated the array, the drives would not be fully utilized, but that if I sent in a log file an engineer would write a script that would allow the full space of the drives to be utilized. However, I was having a bit of trouble generating the log file, and when I contacted LSI again (new agent) I was told that it would not be possible to utilize the space on the drive fully. Has anyone else ran into this with an LSI controller? Also, I'm sure many others have tried to use larger HDDs to increase capacity, have you been successful in fully using the new drives, and if so how did you accomplish this?
Forgot to include: I am running Windows Server 2008 R2 Standard
