My employer is currently working on a billing system transition and with the software came a new provisioning system.
We've been having latency and I/O issues for the past 6 weeks or so, and they've been plugging away at the software core trying to solve those issues.
I discovered today that one of the major changes was a transition to newer/bigger/faster drives and from the current RAID 5 array to a RAID 0+1.
Now I'm tentatively comfortable with RAID and the benefits/disadvantages to each array type. I understand that 0+1 has a higher cost vs. storage ratio - which really isn't an issue in this case.
On the same token, I also understand that 0+1 is ond of the best choices for sheer I/O - but what sort of performance gain can really be expected over the current RAID 5 situation?
I'm hardly fully versed on the situation at hand, being in a different department - but it's my understanding that the current SAN arrangement for the database is the root of the problem, and although they swear the 0+1 will fix all of our woes (and trust me, there's a literal 3 second que time on each query, which means when you're doing point-of-sale you''re looking at a tri-fold increase on processing time for each order).
So... RAID 5 vs 0+1 ? Really all it's cut out to be?
