so i know the deal for the most part and im goin to either go with freenas or openfiler, quite liklely freenas since its bsd based, anyhow
i have alot of drives at home, but theyre not all the same brand.
i do have 4 120gb and 4 250gb all identical model/brand which will probably be the way im going anyways
but i also have some western digital, seagates and maxtors, and theyre all 250gb. though they may have differing buffer size, the rpms are the same. but would that affect anything?
am i better off using all identical stuff are there any benefits, or cons?
going by a quick google i see
Hard Disk Requirements: Minimum of three standard hard disks; maximum set by controller. Should be of identical size and type.
so i guess that pretty much answers my question.
