Everfalling
- Jul 12, 2005
ok, i have 4 300 gig maxtors i wanna tie together with Raid5, but at the same time i wanted to get a 5th to round it up to a TB. so far, finding a controller card for this seems nearly impossible, or at the very least, very very expensive. so i'm thinking of just using my onboard controller and lose one of the 4 drives to parity. also, since my 7800 gtx sticks out inside my case so far, it actually prevents me from using one of my 3.5" drive bays... so i couldn't support anything over a total of 5 drives anyways. ok, so my question is, let's say i have 4 drives on raid 5, but then i buy another drive. is there a way to add a drive to Raid 5 after everything is already set up? or do you basically have to have all the drives you're going to use right there when you make it? Also, let's say i DO get that controller card and the space for a 6th drive, can i disconnect the drives and transfer them over to the controller? pretty much the problem is, even though i doubt i'll fill 900 gigs of space, i have enough stuff already where backing it all up to move the drives might be a problem... so, any do's, don't's, can's and can not's would be great.
