I only asked since I'm seriously considering going with WHS since I've hit a brick wall for video storage. All my other data would fit just fine with room for 100% growth on a 1TB volume. I do remember seeing the SAT2 in his worklog. I should make my own thread for this, but I figured that since that question was on topic I'd go for it.
The main reason I'm seeing WHS as better than RAID 5 is that you get one giant pool of storage, but you only lose what data was on the drives that failed. Like if you have ten drives, the data is duplicated between them all, and two fail that had the same data, then you've only lost that data. With a RAID 5 array, you just lost everything from those two failures. If you only lose one drive, and you put another in for rebuild, then you're also not stressing every other drive when you're doing the rebuild.
