Raid 5 for Security Camera DVR
marley1
Guys I really need some advice. We are doing some IP Camera installs and generally just using a Dell Desktop with a single 2TB card but we are needing to get some kind of redundancy for recorded video.
I am probably going to build a machine with a i3 processor, 4GB memory, etc.
I am looking for a inexpensive Raid 5 card that can run say 4 2TB consumer drives to keep cost down.
Normally I go with a 3ware card but hoping to get something not as expensive.
Do you have some suggestions?
With this small # of drives I would use raid 10 and the builtin Intel motherboard raid.
+1. Cheap card will not be better than Intel onboard RAID. So yes, go with RAID 10 - it's a little more expensive but more reliable.
Do not use a cheap FakeRAID card, +1 to the Intel FakeRAID, they are reliable and have backing and good software support for what they are.
Desktop-class drives are not reliable for such a RAID setup. If this data is mission-valuable or critical, you need to use nearline-class drives or low-end-server-class drives. These drives support TLER or a TLER-like function which is necessary for FakeRAID or hardware RAID controllers.
A nearline-class drive example would be Western Digital RE4 drives.
A low-end-server-class drive example would be Western Digital Velociraptor or Raptor drives.
Both are designed for 24/7 usage, desktop-class drives are only designed for 8/5 usage and do not support TLER functionality most of the time.
As far as hardware RAID controllers: http://www.newegg.com/Product/Product.aspx?Item=N82E16816103229
128MB cache, PCI-E 1x, SAS expander for up to four drives.
Now, if the info isn't mission-critical, then go with desktop-class drives and just use the Intel ICH.
This is just recorded video will need to be using 2TB Drives for storage. What 2tb drives are recommended for that adapted raid card? What is recommended for intel raid?
