Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Sorry, I was thinking of the 2220a. You may be able to upgrade to that card for a reasonable price if you can find someone to buy it from you, but if you decide to try that I'd be sure to call tech support and see if it's compatible with the array so you don't end up wiping everything.
