Raid 5 array with 6 discs
gjvrieze
HI
i am setting up a raid 5 array across 6 Seagate 320gb sata 3.0 on a Asus P5B-D, but when i go into the raid controller, i seem to be limited to 4 drives in raid 5, and i want all 6 in raid 5. Is this a limit, or am i doing something wrong???
Want to say that that board has 6 total sata ports. 4 ports are on the intel chipset and the other 2 are on a seperate controller. Someone elce may want to verify this for me though. Anyway if that is the case your only way to do a raid 5 with all the disks would be a software based one.
Personaly I really don't like the idea of running a raid off the onboard controllers though. I've just seen to many motherboards die over the years. While raid cards do fail it is just not as often.
this board has two controllers, one has the eSata port and another sata port, and then the intel raid controller has 6, and it was my understanding that i could run raid 5 across 6 drives on this controller.
Might be a limitation of that onboard raid. Have you checked the documentation that came with the board? Raid 5 can run on 6 drives easy but the controller might not be able to handle it.
