OlIv0rIolI
- Dec 2, 2005
Hi, l am a desktop user and I want to set up a big storage drive. I am paranoid about hd failures when it comes to my data, regardless of how unprecious the data may seem to most people, so I want to set up a raid 5 system since from what I understand its the safest before going crazy with raid 6. The biggest problem I have is that if I lose my data due to hd failure it would be hard to impossible to replace it. I am storing HDmovies, regular movies, tv shows, music, more entertainment stuff, and most important of all engineering applications iso files and work files. most of it is just for storage purpose. once the files are written there, they will mostly be just read from the storage
I currently have a gigabyte p35 dq6 motherboard with its own raid 5 controller based on ich9r chipset. http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2637
I currently only have up to 1.5tb of personal data to store. and I am going to keep adding to it over the next 6month. I plan to buy 4 * 1tb seagate 7200.11 drives to set it up. so that is 3tb of actual storage.
First question: is this setup a good idea?
Second: is the motherboard controller reliable for this setup? if not which dedicated raid controller should I buy/look for? ( i have no prior experience with dedicated raid controllers)
Third: If I want to expand the size of the raid at a later time, can I add a hard drive and get all the data already stored in the setup to automatically "redistribute" over the new drive?
Fourth: If lets say after I stored the data on the raid drive and then reformated the OS drive. Will the data on the raid be lost ( this might be the case if I go with the onboard controller or in the case that the raid controller failed/required windows driver recognition)?
Fifth: As it always happens, eventually everyone needs to upgrade their pc, so if and when I do, will I be able to move this 4*1tb drive to a new system unscathed? ( this is right now not that big of a concern)
I am running windows xp pro, my system sig is at the bottom. I will also at a later time partition for Vista Ultimate(will Vista see and run this raid drive?)
