RAID-1 SSD protection schemes
This post targets consumer environment. Enterprise Storage has advanced technology to deal with such issues, I think.
A. This is continuation of idea on different thread few days ago
1. In RAID-1, if you wrote X to Disk-1, you also need to write X to Disk-2
2. So if you wrote 20GB data to Disk-1, you probably need to write 20GB data to Disk-2
3. So if you wrote 40TB data to SSD-1, you probably need to write 40TB data to SSD-2
4. So if SSD-1 failed due to write endurance failure, SSD-2 will probably fail soon after the 1st one if both SSD are same model/capacity/partition-setup, in standard simple RAID-1 mirror setup.
B. Counter-measures
1. 1st is to use different spec SSD. Example SSD-1 is SLC. SSD-2 is MLC.
2. 2nd is to use different capcacity SSD. Example SSD-1 is 160GB SSD-2 is 80GB
3. 3rd is mix of different brands/models. Example Intel X25-M G2 160GB and SandForce-based 120GB
The basic idea is by having different specification leading to uneven pairing, it will modify the dynamic of write failure sucession in SSD RAID-1 scenario. This will avoid your RAID-1 to fail completely in short amount of time after encountering write endurance failure.
There is another way to address this issue.
1. Based on idea from Linux MD RAID. I have read-up but I have no experience with actual setup for now.
2. In Linux MD RAID, in RAID-1, you can have special setup.
3. Example, 2 Disks mirror, designate one disk as write-mostly/write-behind.
4. In that case, MD RAID will treat it as such (write-mostly), it will not read from it unless no choice.
5. So RAID-1 mirror
5a Disk-1 = SSD
5b. Disk-2 = Mechanical SATA disk (write-mostly)
In this case, Read IOPS comes from Disk-1 SSD so you enjoy full benefit of SSD IOPS
Disk-2 serves mostly as protection mechanism. In case SSD failed due to write endurance, you can still continue with the mechanical disk. This hybrid SSD/Mechanical RAID-1 setup may be useful in certain situations where you want improve performance but limited fund and you are also worry about failure issues mentioned in section A.
B. Counter-measures
5. So RAID-1 mirror
5a Disk-1 = SSD
