Raid 1 Question
gutkin
Okie, I should know this, but I dont :) Can I have one drive, add a second and convert it to Raid1 without loosing data and reloading? The mobo supports raid1. I accidently miscounted available drive space :)
It should; look at the manual (or post it and someone motivated will look through) to see if it supports cloning from one disk to another. Keep in mind, though - get the wrong disk to copy from and you're screwed ;)
Indeed. PAY ATTENTION TO YOUR SOURCE AND COPY PORTS
yeah, nothing like copying a blank drive all over your data... Really makes your day.
been there, done that
Even worst is tho do that on your wife's computer heh. But yes just be alert what drive you copy, triple check. :D
