Fark_Maniac
- Feb 21, 2002
Long story short, I built a "server" for a non-profit years ago using a Gigabyte GA-MA69G-S3H. I wanted just a tad more redundancy than normal builds, so I spent a bit more and setup a Raid 1 with the onboard SB600 controller with two Seagate ST380815AS drives. One of the drives died and now I'm running on just one drive. I'm very thankful that I did that Raid 1 mirror.
Now my problem is, now that I can't buy new drives to replace like for like...what the heck do I do now? I've done a bit of googling about raid 1 and some have said you can buy a dislike drive, but if it is larger, you only get to use the smaller amount.
The ST380815AS is an 80GB 7200rpm 8MB cache. My thought was to get two new 7200rpm drives. Install 1 and mirror it over, remove the older drive and add the 2nd newer drive...mirror that...now I'd have two like drives again, probably with a lot more cache. Does that make sense? If I don't get the funds for 2 drives, if I get a new drive with 16MB, will that cause any problems??
If anyone has any experience with this controller, I'd love some advice. I do have the WebPam software installed.
