Raid 0 v/s no raid for game rig
schoenda
So I get 2 raptor 150's....strictly from a gaming pov am I better off with raid o or just keeping the drives separate and doubling my capacity? These will be the only drives in the rig.
What do you think? I am guessing not much help in games to have raid...maybe a little quicker load times is all.
Dave
I swear by my raid 0, so fast. But you have a greater chance of losing data, like a huge chance, 50%...
However, you have another option, put Windows and documents on one, put games and programs on the other.
Either is good, but I am a fan of the raid.
Make a small partition, say 20gbs on each and make it a raid 1. Use the rest as bulk storage. Voula ;) safety and speed. Not sure if your controller will let you do that, but windows will (pro).
Depends - If you dont care about data redundancy then raid 0 is the fastest raid level since there is no data redundancy overhead.
If you care about data loss then I would suggest raid 1 with 2 drives. Raid 1 is much faster reading data and about the same writing as a single drive.
If you can swing it you can have the best of both worlds (data redundancy and speed) which would be raid 5 but you need 3 drives.
If you going to stick with 2 drives raid 1 is much better
