NerdzRule7
- Oct 3, 2002
I've been a happy RAID 0 user for over 2 years now. I've had the same 2 seagates running on raid 0 first in my kx7-333r, and now via some sata adapters, on my nf7-s. Recently on my nf7-s though, it seems as if they are bogging down the system. I'll be doing a lot in windows, i love to multitask, and i'll go to do something else and the system will just about stop. I check my cpu usage and its like nothing, but my harddrive read/write light is goin crazy, it looks solid sometimes its going so much. It will stay like that for about 5-10 seconds, then i'll be going again, but it occurs often. I was wondering if perhaps the RAID array is causing this? they are on a 16kb stripe size, it was perfect for my kx7 and everything i did on that, so i thought it would work good here. Is my stripe size slowing me down? or is it perhaps the sata converters. I'm not sure what i'm going to do... though i might buy a single raptor which would be about the same size as the array is now, and most likely faster. any thoughts on how to fix my slowdown are appreciated.. thanks-The_Nerd
