Raid 0 results, and help finding longer cables!!
nintari
Just setup my new system and had some drives from a server at work I recycled and setup a new WHS. Well since the OS disk IO on the WHS wasn;t going to be intensive, just the data side, I decided to take the 3 SAS drives and RAID card and put them in my new rig.
The drives are 3 Seagate ST3300555SS 10krpm 300GB drives
The controller is a Dell PERC 5/i wiht a LSI Logic 62089a2 chip on it. 256MB memory is installed
I'm looking at different options now for cables (these are waaay too short!! I made them work for now by bringing my HDD cage back some but now it is really tight and not enough airflow)
Cables seem to be a pain, looks like I have to buy adapters to convert the SAS to seperate power and SATA
http://www.impactcomputers.com/my306.html
and then a cable like this one:
http://www.buy.com/prod/cables-to-g...red-cables-to-go-sas/q/loc/101/207468064.html
I'm looking to see what I can do to get this runing a little better because my benchmarks seem a little low compared to some others. Might need to update firmware and change things in the card settings to get it running better (strip size, caching etc)
HD Tune results:
the hard drive has SFF-8482 connector and the 5/i has SFF-8484 connections right?
why not one of these?
thats the majority of what I am finding right now, I was hoping for ones that I just atatch the SATA power conneciton on instead of the dangling molex connector.
Finally got my CPU straightened out, I installed the stupid coolermaster N520 backwards :( thought I had it right but it wasnt. i5 750 o/c to 4.01GHz max temp is now 84c which is still high but better than the 99 I hit lmao. But that is with a ton of fans going in the system! but that is for another thread in another section.
Really I think it is just these 10k rpm drives heating up too much of the incoming air and running it throgh the processor.
Your drives aren't putting out that much heat. We have a server at work I built with 4 15,000 RPM SAS drives in RAID 10 and they really don't heat things up that much.
compared to a single WD Black... there is more heat :) plus the controller card is meant for forced air systems and while I have decent cooling it gets hotter than anythign else in the case! I cant even keep my finger onthe heat sink for more than a second.
I've had the PC out in my car for a while (just brought it home from work) and fired it up and am running prime95 on it now and so far Ihavent gone past 77 on my cores.... trying to let it sit for a while to make sure the cold from sitting in the car isnt effecting things too much. But could have been hotter at work too.
Anyway back to the RAID, I seen one benchmark someone did with my card and 4 Samsung F1 1TB drives and he got an average of 391.7 MBps!! I WANT THEM!!! (although looking again it looks fishy cause it says the raid array is 2199GB for RAID 0)
http://www.overclock.net/raid-controllers-software/359025-perc-5-i-raid-card-tips.html
lol I just noticed my windows experience index remains unchanged from a single 7200 RPM to this RAID 0 array, 6.9
(yes I refreshed, this is a clean install on the raid)
