Raid 0 Problems
Morazl
Just got a new system, and windows will not detect the Raided hard disks. and I installed the Raid drivers off the windows cd. I am using a 40gig hard drive as master (drive for the OS) and two seagate 120gb sata hard drives. (RAID 0). If you can help me out I would appreciate it.
Did u set up the partition with ctrl+F or ctrl+L depending on your controller? ARe u using software raid from your mobo or a RAID card?
and you're mobo supports RAID right?
