RAID 0 of cheaper SSDs
Yossarian22
I'm currently looking into ways I can increase performance of my computing experience. Already, I have a modest CPU and GPU, but I was wondering if there exists data on RAID 0 of cheap SSDs and if the entire concept is worth the effort.
I ask because write speed (sequential) is generally bad with a singular drive.
Has anyone here done, tried, or looked into such a venture? :confused:
Your Sequential read/write will be great, but cheaper SSD's generally have lower quality Random read/write. So your doing 2x or 3x or 4x 1-2MB/s on the 4K Random where as a single Intel will do like 40MB/s (or much more) just by itself.
Its not just the size of the drive that makes them expensive, its the complexity of the controller.
But remember there is always rediculous like this article
http://www.nextlevelhardware.com/storage/battleship/
** Remember that was back in 2007 **
I would say it's not worth it unless you are getting the drives very cheap like under 50 bucks each. Because you can get an ocz vertex for about 100 bucks and it would perform better. In addition buying a single Intel would be better for an operating system than raiding two ocz vertex. So as you go up the chain there are big improvements in the drives. Raiding some intel drives now that would be sweet.
You can get a nice single SSD that will read 200MB/sec and write 110MB/sec and that is NOT bad at all. The cheaper SSDs have like 40MB/sec write speeds so it would take more than two in RAID0 to really feel a big improvement over one of the drives that writes 110+MB/sec. There are some mid-level drives that write at around 70MB/sec, but usually a couple of these are no less in cost than a single fast drive of the same amount of storage, and usually not much faster in RAID0 (120~130MB/sec writes with two).
I got lucky and got a few cheap engineering samples of Intel X25-e's.
I haven't even raided them yet, but I will soon. You lose TRIM supposedly, when you raid drives that have TRIM support. But even then, when you raid 2 to 3 drives, write speeds will still be acceptable. And for how much the X25-e drives are, they are 1st generation and don't support TRIM. For that retail cost!! :rolleyes:
Edit: If you can't really afford to dip into at least a couple, then wait it out, load times aren't instantaneous like you'd expect. They do perform faster, but with my real world experience with them, I expected things to be seriously fast. Also, raiding more than 3 will require you to get a server level RAID adapter, which are EXPENSIVE. You can easily max out the bandwidth of onboard RAID controllers on your motherboard.
Why not just raid a few standard HDDs (just make sure you backup your data)
you will end up with a lot more space and pretty good performance for a lot less
Low end SSDs just are not worth it, and high end ones are only good if you have loads of money to spend
