Raid 0 array failure
setter
A while back i was running 2x74gb raptors in a raid0 array, i started getting various errors such as, a drive in raid has failed.Then other times windows would boot fine. I took the two raptors out of my system and switched to a single drive, changing boot from raid to ide. Im considering moving the raptors to separate machines. Would i be best reinstalling them and reformatting them, as the raid array is still setup in the raid configuration setup in the bios. Thanks for any advice.
Go to the support section of Western Digital's website and get the Data Lifeguard for Dos CD version. Boot from the CD you burn, and run the complete or long test on both drives. If they give you any errors, then check to see if they are still under warranty.
You may have to remove them from the array for DLG to find the drives.
Don
