I'm looking for a way to keep large amounts of data on my PC without having to worry about hard drive crashes... when you have 2 IBM 60GXP's crash on you within 2 weeks of each other and they were in RAID 0 you get paranoid.
Anyways, right now I'm running a Single 200GB Seagate drive, I was looking at either
1. Buying just another drive. This doesn't help with data redundancy of things like movies, music, pictures, etc. but hey it's more storage.
2. 4 320GB WD drives in RAID 0+1 for redundancy. Theoretically 2 drives can fail and the data isn't lost. Do I need the RAID edition drives if I'm using the NF4 controller for RAID 0 + 1? I have a DFI Lanparty UT NF4 Ulra-D
3. Raid 5, which requires more drives and a $500 controller card. Not even looking at this solution until the price comes down.
So basically I'm looking at #2, so I can keep movies etc. on my hard drives without having to worry about burning them to CDs or whatever since that is a pretty huge pain. That and CDs do seem to break down after a few years.
My question is basically how would I go about moving my data from the single drive to the RAID 0 + 1 array? Could I:
1. Install 2 disks in RAID 0
2. Use xxcopy to clone the contents of my drive to the new disks
3. Re-assign the new drives as "C" in windows without making it blow up
4. Remove old 200 GB drive
5. Install 2 more drives and convert array to RAID 0 + 1 without losing data
If that process isn't viable, is there one that will work, perhaps using Norton Ghost? Also, can the raid 0 array be converted to raid 0 + 1 on the NF 4 controller without formatting/losing data?
Also from a future-proofing perspective, can extra drives (in pairs) be added to a raid 0 + 1 array without losing data on the existing array? Or does the entire array have to be formatted? As you add more drives the efficiency of the array starts to become more of an issue cost-wise; 50% storage capacity sucks vs (n-1) that raid 5 offers. Right now the NF4 board only supports 4 drives, but in the future if I were to move to another machine entirely, I wouldn't have to reformat the drives if I were still using raid 0 + 1 would I?
One last edit: for the on-board NF4 raid 0 + 1, would it be recommended to get WD's "raid edition" drives with TLER, or is that only required for separate (pci/e/x) controllers? It's not really clear from WD's documentation.
Thanks.
Thanks.
