radiator with the lowest width?
xdkimx
which 120mm single fan radiator out there has the lowest width? "HxWxD"
the narrowest one i could find was thermochills he120.1 which they say is 172x124x50mm, anyone know of a narrower one?
you want the width not the depth right? If that is the case I think you have found the narrowest one. (not sure about the PA 120.1 though)
EDIT : Of course you do know that the difference between the majority of 120mm radiators is around 10mm or less. So you aren't talking about much variation. I think the HE is 124mm, PA 127, BIP and BIX are 133
i cant think of a radiator thats narrower than a thermochill, unless you want an 80mm rad. :)
