It shouldn't be too bad -- but it depends on the flow rate, the fan speed, the size of the radiator, how much you overclock the processor.
When I was helping my friend build a CPU isolated WC loop, i think the air was about room temp, to be honest. but YMMV
A cubic foot of air can hold a lot of heat before warming up. Air exiting the radiator under normal conditions should be 2-3c over room temperature - and 5-6c over room temperature during sustained load.
ok.
Is there a Way I can get hot air out of it ? Without bumping the cpu temp to 65C
