Radiator question
Either way the difference IRL isn't much. A handful of Watts either way. +/-5-10% at most.
The UT60 is a top performer no matter what fan speeds you are running, but if you are going to be using low speed fans you could save money and still get almost the same performance by going with a slimmer cheaper radiator. The UT60's performance lead increases with fan speed.
Black Ice GTX radiators have the edge at high fan speeds, especially in push/pull with high static pressure fans. The high FPI design of the GTX radiators is something the low FPI UT60 can't compete against.
Of course, at low fan speeds the UT60 is favored.
