Radiator mounting screws/nuts?
Dethred
Hey guys, I'm looking for some screws that are long enough to mount my radiator outside the case, but I need some nuts to secure everything to the case as well. Does anyone have the diameter and thread size for such screws so I can get them from a hardware store, or is there any online store that has them as well.
Radiator should've come with a set for mounting fans -- holes on the other side should be same thread. Bring one with you to the hardware store and buy a threaded rod to match. There should be a thread checking jig there. Get the nuts to match the rod, and you're set. Buy long and break/cut off to length once it's mounted up. Be careful you don't run them in too far and pierce the rad tubing.
