CompMage
- Sep 7, 2003
Ok I'm going to be working with a Corsair 750D
I'm going to be cooling a Skylake board and chip, (When ever it's out) and 2x GTX 980 in a single loop.
I was leaning to 2x Black Ice Nemesis 280GTS® Ultra Stealth U-Flow Low Profile Radiator in a push pull with some high pressure fans. Not that concerned with that much noise, but the ability to tone them down when not gaming. Or go with a single 360GTX, but I would like the extra cooling off the CPU before the GPU or the ability to later change to a dual loop if temps or pressure just will not keep up.
Res > Pump > Rad > CPU > Mobo > Rad2 > GPU1 > GPU2 back to Res.
Going to be using all hard-lines because it is cleaner looking and helps with the head pressure (Not much but every tiny bit helps in longer loops).
