Radiator decision.
michaLcoughliN
The only thing im unsure of is what radiator to choose, in my WC gear im about to purchase.
I will be cooling my cpu / gpu.
Dtek fuzion
Ek waterblock
MCP655
Rad is undecided
So I've heard that the thermochills are the best of the best. Ide like to get the 120.3 but I have never seen them in stock ever. (Im in Canada, dont like buying from the states do to customs)
So any other choices? I was thinking on getting the 120.2 but would that be enough?
or does the mcr320 work well and cool just as good.
Help is appreciated.
120.2 is about equal performance to the MCR220.
Imo the MCR320 is the best price/performance.
120.3 is just flat out best but only by a few degrees.
How about adding 2 x mcr320 in 1 loop. Would that rectrict flow? and possible advantages in adding 2 rads in one loop?
I answer you question @ Extreme Forums too. For me the reason i have two MCR320's is because i can run passive Q6600 if i want. About the flow i have MCP655 and trust me it did not made any difference i see water rushing in the reservoir and making whirlpools.
PA 120.2 would work, just put some decent fans on it in a push/pull config. Thermochill are thicker but the swiftech has a higher fins per inch count. You could go with a mcr320 with lower flow fans, or 120.2 with higher cfm fans.
i think annaconda already answered your question but yeh you would get nice temps... ive seen those rads and i would defo buy them instead of the thermochills for the price difference.
Well you can buy x2 mcr320 for the price of 1 pa 120.3
I dont see many people with dual rad in 1 loop.
I' ll do it if it truly benefits the cooling process.
