CompMage
- Sep 7, 2003
Well it's that time finally after several years in place to upgrade my setup.
Since Radiator and Block tech has not really changed much in the last 5 years (lets face it the laws of thermal dynamics don't change) I need to do some cleaning. I have to admit I've not flushed my system in 2-3 years. Just added to as needed. I've been using Premo-Chill for coolant and it's worked out good so far. I've lost no hardware over the 2 OH FUDGE moments since I've started using it.
Right now I am considering a diluted solution of car radiator cleaner (peak) and running threw the loop for an hour or two. My main goal is to clean out the radiator as everything else I can take apart and clean by hand.
During the clean I was going to have it just my pump, the radiators and old reservoir I don't use anymore. On the re-build I'll be using all new pipes and fittings.
Anyone else have experience with this or other suggestions.
