radiator bolts - flush / flat head?
Momo
Anyone out there know where I can find these / what the proper industry name for a bolt designed like this would be?
I want a magnetic filter i've got to sit flush, so it's either modify / hack job the filter frame, or spend a few bucks and get the proper bolts.
well, using the mcmaster-car link, i found the head type i'd want, an undercut flat style, but they only come up to 1" length.
Using boltdepot, i found it within abuot 5 seconds:
see this linkhttp://www.boltdepot.com/Machine_screws_Phillips_flat_head_Stainless_steel_18-8_6-32.aspx
... does that look like it would work to you? think case-fan-screws, they sit flush, so should that, right?
Yup.
I bet you can find something similar at HomeDepot....ie 6/32 by 1 1/4 or 1 1/8 inch......
The fan casing is 25mm or 1 inch......you want about 6mm more length so you dont screw the bolt into the radiator channels:eek::eek:.......so 1 1/8 is about it......or 30mm.
Just be cautious when screwing the bolt into the radiator braket.:D
.... d'oh! boltdepot doesnt ship outside the US :(
at least i know it exists. Time to start asking around town ;)
the one provided by corsair are 1.25", but they are intended to be used with the included washers.
So yeah, i'm thinking i need something that's 1 1/8"
... if the bolt is a mm or three too long, doesnt it just impact fins (that arent getting any airflow anyhow, under the rad shroud)? arent the channels farther into the 'core' of the radiator than that?
No.:eek::eek:
ok, so just how much 'fin' is there, before they attach to the channels? ;)
oh, and i had to order 100 of the 1-1/8" flat head #6-36 stainless steel from a supplier. Fastenal.
