Hey guys, been browsing this forum (as well as a few other sites) for a couple of days but seem to be reading a lot of contradicting info. I did do a search and couldn't find an answer but I apologise if I'm rehashing an existing thread.
Obviously I'm new to water-cooling but I have learnt the basics already, I am just struggling to work out a couple of things...
Firstly how much radiator space is needed to cool;
i7 2600k
Gainward GTX 580 (3gg) x2
Northbridge
memory (if I choose to, probably leave it air cooled)
The case is the Corsair 800D so space is no issue and 1 3x120mm radiator will be in the purpose built bay at the top no matter what.
The layout will be res/rad/pump (in whatever order they fit best in the case) -> CPU -> split ->
chan 1 top gpu -> RAM (again, if i add that) -> rejoin
chan 2 bottom gpu -> chipset -> rejoin
rejoin going back to res/rad/pump.
If i need another rad I assume it should go after the cpu and before the split? Or am I going to be better off going the split to two gpu's then rejoin -> rad -> cpu -> rad/res/pump
The second question is the pump, I cant seem to find good info on the choices. Obviously I am looking for a system that is as quiet as possible but I have read that there is such a thing as moving the coolant too fast so what sort of power is needed for the layout above (assuming no ridiculously long tubes since I can fit 3-4 rads internally if needed)
Just had another thought too... only 1 rad will be in an ideal spot (purpose built bay at the top of the 800D), any others will inside the case with a slightly higher ambient temp being blown over them, is this worth worrying about at all (as in changing the order of the rads)?
Thanks for any help, so much brain overload going on atm!
i7 2600k
Northbridge
