I need some help here people! The Rad I tried to mount in the top of my case sprung a leak. Ok I put a screw in it. Anyway I bought a heatercore and a shroud.
I loved the look I had before-
The new rad mounts pull the two fans apart, leaving a gap to fill or I can flip the fans inside and mound the core to the top flush.
I really liked the fans up top however they were exposed and fingers could be hurt.
This is the Core and shroud, PrimoChill HE-Core 2x120mm. And the Smoke colored shroud.
The question is do I try to keep the fans on top
and the air blowing -IN
or
The fans blowing out I will make the hole square with the rad blow air -OUT
or
the same fan inside - IN
This system will be totally watercooled-
1. CPU-Apogee GT
2. Video card 3870 with the MCW60-R
3. N/B MCW30.
I do not believe there is anything putting out enough heat to run the case warm and there are (2) 120mm fans blowing out the back of this case with 1 120 for intake that blows over the Harddrive.
Can add another 1-2 in front or bottom if needed.
Thoughts and opinions welcome but hurry!!! I wanna finish this case before AMD comes out with an umber CPU. LOL
or
or
1. CPU-Apogee GT
3. N/B MCW30.
