Radeon Xpress 200M chipset
hansokl
I am trying to switch from the intel celeron 1.6gighz 1mb L2 to the Intel Core Duo T2400 1.83GHz / 2MB Cache / 667MHz FSB / Yonah / Dual-Core / Socket 479 / Processor and I was wondering if its possible? Thanks
Here is my chipset for my celeron 1.6
I want to upgrade my cpu so im guessing a duo won't work but would a p4 really work in my notebook and should I do it?
I just found this out on the Radeon Xpress 200M chipset
CPU Interface
Intel ® Pentium® M, Intel Celeron®, Celeron® M and Intel Pentium® 4 processors
Hyper-Threading Support
Support for Enhanced Intel Speedstep Technology
Supports Advanced Power Management with CPU Throttling capability.
Memory Interface
UMA mode operation requires no additional memory
DDR and DDR2 Support
DDR Speeds up to 400mhz
DDR2 Speeds up to 667mhz
Support for 2Mx32 (with 64-bit interface), 4Mx32, 8Mx32 and 16Mx16 memory devices
As a rule with a notebook you won’t have the bios choices you do with a desktop and it’s rare that most manufactures will help you at all with that.
Run CPUZ, the latest version and see what version CPU you have now then Google compatibility. Keep in mind many notebooks have the CPU soldered in place which unless you have a serious soldering station is a project stopper.
I’ve done two notebook upgrades and both were nightmares. The other two problems to consider are can the power regulators on the motherboard handle the new load and then if then can, what will you do with the extra heat?
I guess the third big question is, how adventurous do you feel?
Luck;)
Some added info:
http://www.hardforum.com/showthread.php?t=1106040
Thanks for the help. I would love to run cpuz but my harddrive went out. I have to deal with that first.
