Radeon X800
If you get that^ card are you planning on trying to open the disabled pipes? If so then yes its a good upgrade from your 9800Pro. If your not planning on moding the card then go with the X800XL.
Currently the XL is only on PCI-E. R481 should be coming to AGP soon. An X800Pro is a good upgrade from a 9800Pro regardless of whether you open the extra pipes.
How exactly do you open the extra pipes? I also cant find the X800XL... I could only find X800 PRO, and X800 XT. A link to it would be appreciated as well.
