Radeon x1650 Pro Issue
Hourglass
So I'm trying to hook up my 37" vizio lcd to this card and it's not going very well. I tried hooking it up with the svideo cable and it could not find the TV, I also tried just the yellow composite cable and got nothing.
Does anyone have any suggestions on how to get this working?
Both the VGA and DVI are used with lcd monitors.
When I run s-video on anything bigger than 30" TVs I am not satisfied with the picture quality. Some of the best results I've seen have been with DVI/HDMI cables, the picture is amazing even on +60" screens.
As for it not recognizing the TV...I have no advice as everything I have hooked up has been recognized in the CCC panel.
so are you saying you are trying to hook up a third monitor to your card?
i may be wrong, but i dont think you will be able to run 3 displays, have you tried to disconnect one or both of the other displays to see if it works?
hmm
I'll try that, I was just think about that myself, I'll let you know how it goes
Typically, if I remember right you need two separate cards to run a total of 3 screens, although I have never tried myself, I just remember hearing that somewhere. I don't know I could very well be wrong.
